Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Johnson Mile Master pressure tank
  • Johnson Mile Master pressure tank
    I just ordered the diaphragm (pt# 302563)for the tank because my last one was cracked. The one they sent me has a hole in the center(where the crack was) where the primer is located. Is this the wrong part or is there one without a hole in it.Thanks,Just trying to get running.
    Re: Johnson Mile Master pressure tank
    Hi Ten Do you have a plastic primer button?
    • #3
      Yes. plastic Primer button - diaphram - metal plate attached to spring.
      • #4
        Hi TenIf you have the plastic primer button, you need diaphram part# 376987.
        • #5
          thank you, do you know a good place to order. my motor place cant order unless $50 spent. can you get just a tank repair kit.
          • #6
            Hi TenCAN'T, I hate that word. What they mean is WON'T. I'm sorry I don't know where the most convenient place for you to get this part. How ever they are not rare. Just start calling around till you find someone who will drop one in the mail to you. Of course you'll have to have a credit card. It may be a good idea to replace all the gaskets while your at it.
            • #7
              Right now there are some on ebay.Search under Johnson outboard.
              Make sure the plug is in
              • #8
                thanks for the help. found tank repair kit at laing's outbaords.
