Jason Micallef
- Jun 7, 2014
- 32
Hi folks, Thanks for any advice in advance. I have a 1988 evinrude- 115hp -V4 with possible cooling issues. VRO Oil injector disconnected, gas ratio 50:1.
I notice when I run my motor with earmuffs in the driveway for 2 minutes. I get a series of beeps from the ignition beeeeep.... beeeeep.... beeeeep.... beeeeep. Turn the motor off ,check it over half the engine is alot hotter on the right side. I belive it is, standing at the back of the motor on the right top cylinder # 1 and bottom right cylinder # 4. Those two get alot hotter than # 2 and # 3 .Changed the plugs and wires ran "ALOT" better still the same issue. Rebuilt both carbs again ran even better with the same issue. Any ideas or opinions would very much be appreciated. OH! .....one other thing the fuel pump slash old oil injector that is linked together...... I hear a clicking sound coming from there not sure if that was normal.
Thanks -Jason
Thanks -Jason
