I bought a ranger bass boat used and the first time I used it ideals fine but when I engaged it bogs down and cuts off. I was able to run it about 100 yards then cuts off again. On and on same thing happens. Question I have is the primer bulb supposed to be flat when running? I mix the oil and gas so it could be off slightly in ratio. The battery was not charging and I had to put jumper cables to the other battery. When I start it the alarm goes off and I don't know if it's the low battery or if it's something other reason the alarm is coming on? Help please.
