Re: grease and water shooting out the prop
Rob,<br /><br />I don't know how long you've had this engine.<br /><br />If it was "fogged" before laying it up, the gunk coming out is just the remnants of the fogging oil. It will clear itself up.<br /><br />You're always going to get some crud out of a 2-stroke exhaust.<br /><br />Check the fluid in the lower unit first. Make sure it's full with no water in it. Make sure you replace the fill/drain plug seals!
