jakedaawg
- Jun 26, 2012
- 4,275
This thread is intended to document the rebuild of this engine for my partner in the boat. He wants to follow along while he is away.
Should anyone see anything I am doing wrong feel free to comment.
Well Cap, as you know we had the following compression readings: #1=125 psi, #2=125psi, #3=125 psi, #4=102 psi.
Several methods of decarbing stuck rings were tried. Result was ~ 5 psi gain. still not good enough.
I pulled port head.
I pulled port head.
