1977 35h johnson stick style steering
WisconsinNugs
Instead of a steering whell i have a stick by my counsel forward right back left. the cable running to the motor is frozen or something can you grease it. i see no fittings. i need a new cable???
digimortal777
Re: 1977 35h johnson stick style steering
thats either your gear shift or your throttle control<br /><br />your cabel is probabaly siezed , get a new one
NMplayer
No digimortal, he has stick steering. I don't know a lot about it but usually when steering goes bad, all you can do is replace the cable. Do not try to force it or you may end up ruining the control which will cause a lot of expense and headaches.
D
DJ
Guest
WisconsonNugs,<br /><br />Yes, you have stick steering.<br /><br />I don't like them, too confusing.<br /><br />Anyway, it is probably a Teleflex/Morse system and is of the rack and pinion type. You'll know as soon as you get it out.<br /><br />The cable is either frozen internally or most likely at the motor end. Once frozen they are junk. You can buy new cables.
WisconsinNugs
so i have to buy a whole new steering system, because the cable going to the stick says factory installed do not remove or replace(this is written on a red ribbon)
D
DJ
Guest
If that's what is says, then yes. The "head" assembly is not that much extra.<br /><br />You can find steering assemblies here on iboats.
