Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
how to adjust- too lean/too rich
  • how to adjust- too lean/too rich
    I'm working on my 1981 Johnson 60 hp (2 cy) . I often hear about adjusting your motor if its running to lean or too rich. My question is, what is the proper way to do this. It seems my motor smokes a lot, does it mean it running too rich or too lean. Any way, any advice on how to go about adjusting fuel mix is greatly appreciated. By the way, What screw do I adjust, there's a screw ontp of the carb an one near the bowl. Mahalo lc
    Re: how to adjust- too lean/too rich
    Aloha Ic,Your carb has no adjustment for mixture.It has fixed orifices.Here's a fiche of your carb.remove the screw caps and insure the orifices #37,#9,and #35 have no gummy deposits obstructing flow.A torch tip cleaner set works good for me. 81' 60 hp carb
