Highlife
- Jul 24, 2011
- 44
Can you add a tell tale to this motor? Yes/No. I have heard that you can but haven't seen very good directions on this. I have heard you have to drill a hole and tap threads into the top of the #1 cylinder water jacket, then run the small hose down to the location you want it to come out. Question is, do you have to pull the head off ? or can you just drill with oil to help capture the metal filings. also does anyone have better directions / videos on how to do this. Thanks Highlife
