Stankbait202
- Jun 16, 2014
- 6
Just acquired an good running 1975 Evinrude 135hp. had to tear apart and clean the PTT motor because it had been sitting for 4 years and was seized up. got the motor back together and running good and when I went to check the fluid noticed it was heavy and appeared to be lower unit gear oil. is this the proper fluid for this? I know it seems to be struggling and the wires are getting pretty warm. all the wiring needs to be re-done because of a terrible job the previous owner did of wiring. lots of corrosion, exposed copper and tape everywhere. But I think the heavy oil is putting too much load on it also. Thoughts?
