I have a 1970 60hp evinrude that has no power under load. I have replace all the fuel lines and connectors, new fuel pump, new plugs, and rebuilt the 3 carbs. It will sometimes die at idle but not all the time. When I run it with the miffed everything seems to work fine till I put it in the water. During idle if I pull the lower plug wire there is only a slight change in idle not much. If I pull any of the other two it dies. If any one has any suggestions please help. Thanks
