Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
trim tabs or fins??
  • trim tabs or fins??
    im thking of puttin trim tabs on my row boat but i am unsureare the fins you can get for engines any good , i cant remember what there called but they go in the cav plate???the reason i ask is that there was work done on my stern at one time and i might not be able to put tabs onto it (long story)i have an 18 ft rowboat with a 68' 9.5 johnson
    Re: trim tabs or fins??
    are they called doel fins?
    • #3
      Yes, that is what they are called. They make two kinds. One that is a solid one piece design and the other type which you refer to which are two seperate fins that bolt on. All these mount to your cav. plate and are a lot cheaper than trim tabs. On your rig I would think it would help you get planed a little bit better. Only $27.00 at west. I wouldnt spend a whole bunch as no matter what you put on your setup, with a 9.5 pushing it, it will not jump on plane and run fast. This may help you though. Good Luck [IMG]http://www.***************/images/full/06534_f.jpg[/IMG]
      • #4
        Go with the fins I don't think that tabs would do much for the set up you have the fin should help you plane better.
        • #5
          I think the fins are the best performance addition for the least amount of money. Wal-Mart carries the Sting-Ray and they have a lifetime guarantee.
