• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
73 Evinrude 50 HP OB engine (LARK)
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 73 Evinrude 50 HP OB engine (LARK)
    Ok I got my motor running as perfect as I could get it it's running like a champ I checked all the wires and everything else I have no clue why I'm still running at half power!!! but get this when I put it in reverse I have power for days and it sounds like it's hauling butt it sounds the way it should sound when it's at full foward!!! is something installed backwards?? when i had my tune up or my powerpack replaced???
    Re: 73 Evinrude 50 HP OB engine (LARK)
    Howdy, Fabuglas.You are probably running on one cylinder.Find out which one isn't making power. Pull each plug wire while it is on the muffs. If it dies, that is a cylinder making power. If nothing happens, that is your dead cylinder.Now check the spark on the dead one. Pull the plug, hold it against the block and turn her over. If you have spark, spray some fuel mix into the carb for the dead cylinder. If it picks up rpm, overhaul that carb.Let us know what you find.Oh, BTW, get a manual.
    sigpic
