• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
90 hp Evinrude -- Fuel Problems??
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 90 hp Evinrude -- Fuel Problems??
    I just bought this motor. 1984 90 hp Evinrude E90 MLCRD It has the VRO option (there is a seperate tank for the oil.) The previous owner obviously had some problems with it; the spark plugs and coils are new. Previous owner ran it "a couple of times over the last three years." So, before I ran it, I siphoned old gas out of the tank and refilled with new gas.Problems:The engine is a little difficult to get started and once it finally starts the engine will not idle without the fast-idle lever up. (This makes it rather difficult to get into gear!) Once I get it into gear and slowly accelerate, the engine "misses" a little. ...as if it isn't hitting on one of the cylinders. Once I get the engine up to about 3000 RPM (about 25 mph for the boat) the engine will slowly sputter down and die. If I wait about 5 seconds, it'll start back up again. Sometimes, it'll be sluggish to crank over when this happens. (I have a brand-new battery.) It'll run fine as long as I keep the RPM below about 3000. The engine is not getting excessivly hot and there are no buzzers or horns sounding. The tell-tale jet is strong. There are no funny smells or sounds. There are no fluids leaking in the engine compartment (that I can see.) All the linkage seems to be working fine. What I've done so far:Replaced the fuel filter. Replaced the fuel line from engine cover to tank (including the bulb.) Removed, flushed, and re-installed the gas tank. I've checked the tank vent; it's not blocked.What do I do now? Is this a common problem with an easy fix?Any and all help would be appreciated.KS in TN
    Re: 90 hp Evinrude -- Fuel Problems??
    Did you clean the carbs?You might have a blocked high speed jet. Depending on the design of the carbs this would also contribute to the hard starting and lack of idle.
    • #3
      I'm working on rebuilding the carbs now. Any suggestions or tips would be helpful. As I was removing the carbs I noticed the "clear" oil tube that goes to the VRO unit was cracked/broken. It is fragile with age. I'm not sure if it was broken prior to my tugging on the fuel line... It needs replaced if I'm to continue using the VRO system. Any ideas where to find this part? If this was broken prior to my tinkering what would be the "symptoms" of the motor? Would they be similar to what I've described previously? Should I run a compression check to make sure there was no damage? ...sorry for all the questions; I'm new to outboard motors.KS
      • #4
        Kansas...I would definately do a compression test. You could have been sucking air instead of oil. If compression tests good I would plug the vro where the oil line hooked into and primix some fuel and run thata way until you get the bugs worked out, then if you like the vro feature get it working properly and use it. Sounds like you do have a fuel delivery problem, check all the little crevices and holes in carb make it spotless. Check all the spark plugs for good spark and good clean plugs...if all is good run it on premixed fuel. If the problem stays try pumping the primer bulb when motor starts to slow...if that helps you might need fuel line parts or fuel pump...just a Thought
