• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Spun Prop?
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Spun Prop?
    I had a great day yesterday on Long Island Sound. Didn't catch much but had a lot of fun. I had just put my boat in for the year that morning. Everything went very well - the motor started easily, plenty of power and great weather.On the way back in, I was hailed by a sailboat that was stuck on the reef. I went by to try help but I do not know the reef well enough and therefor advised the guy to call Seatow!On the way back in it was very choppy (2-3ft). I decided to increase speed to get the bow up in the air. That's when I noticed the engine rev up and the speed not increase. I decreased rpm's and everything was fine. I did not hit anything (bottom or reef) while out.Later, I tried the higher rpm's in calmer waters and the same happened. I have a 1984(?) Johnson 60HP outboard. The prop is marked 11 3/4 X 17 and it pushes a 16ft MFG.A couple of questions: Is the prop spun? Can I repair/replace myself? Is this the correct prop?Thanks in advance for your help and time.Liam
    Re: Spun Prop?
    The clutch or hub in the prop is slipping. You sould be able to remove the prop and have the hub replaced or replace it yourself. I think some of them may press in but the only one I ever changed was on a suzuki 65 hp. It just slipped inside the hub on the prop and over the output shaft on the motor. Real simple to fix and less than $20.00.
    • #3
      Re: Spun Prop?
      Thanks for the info. I have been told sometimes you must replace the entire prop. Is that the case with this motor?
      • #4
        Re: Spun Prop?
        You got a spun hub. You can have the old one pressed out and replaced for about $40. Merc makes a composite two piece hub for their props, but I do not know if one is available for your prop.
        • #5
          Re: Spun Prop?
          LiamI seen a lot of Johnson with spun hubs but never saw one you can get out or put in with out a press. As far as the right pitch I do not know. Did motor run in proper RPM range at full Throttle before, if it did then you have the right prop.
          Have some fun and enjoy the Great Outdoors.
          Love to fish out of Bodega Bay, California.
