• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Johnson stalling/lack of power
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Johnson stalling/lack of power
    MOTOR: 1996 Johnson 175FS. Pretty low hours and not driven hard. Motor had a tendency to stall on acceleration at the carb transition point.(going thru 1800 RPM's) I found somewhere that the initial setting for the idle screws was 8 turns out. Screwed all the jets in and backed out 8 turns. Seems to run OK when cold, but as the day goes on the stalling problem gets worse. Just a bit of choke fixes it (temporarily). Yesterday (for the 1st time) I noticed a definate lack of power trying to get on plane. After it was on it ran fine. This only happened later in the PM (91 degrees F) and the engine was fully warmed up. Do I screw the jets out farthur? How far can I go? Idle's fine. WOT fine. Checked throttle sync-OK. Used an air flowmeter on each carb-all the same. New plugs. Good gas. Will do compression ck today, but have no reason to suspect a problem here.ThanksTom Lea
    Re: Johnson stalling/lack of power
    It sounds a bit like a vapor lock (heat soak) problem. Vacuum check your fuel system at all speeds and make sure it is less than 4" of restriction. Set the synchronization to have the carbs start opening 1 click after the spark advance. What is your top rpm? It should be close to 5500 rpm. Use Champion QL78YC plugs gapped at .030". See a knowlegable dealer to see if your motor was included in a service bulletin about changing nozzle vent sizes.
    • #3
      If it's heat soak, how's come ALL (or a LOT) of Johnsons don't do it?Will do the fuel vacuum check tomorrow!Top RPM right at 5500-5600Will TRY this spark advance setting. Have a book and some knowledge and will give it a go.Been using Champion QL77CJ4 plugs.Will try the QL78Yc's tomorrow too.Will check with dealer tomorrow too.Is there anywhere on the Internet to find if the motor was included in any Tech Service bulletin's?Thanks for the helpTom Lea
      • #4
        I do not have an answer to your problem, but I noticed that you have a Johnson 175 that is one year newer than mine. I do not know if the fast strike is comaparable to the oceanrunner model that I have, but maybe you can help me. I have a couple look vacuum lines that I do not know where to hook them up at and a red switch on the fuel system that I do not know what position it should be in. Can you look at your motor and let me know where they go. I can be reached at gs0010@hotmail.com..
        • #5
          H-E-L-POn the lake today: RPM's 5600. Fuel vacuum 4" with an occational jump to 6" under throttle burst. Spark plugs - QL78YC to .030"**** thing ran great. Only a minor hesitation on initial acceleration and I think that could be carb idle adjustments. THE DIFFERENCE: I did not have the cowling on today. There was no heat build-up under the cover while sitting in the sun! What's under there that is so affected by heat build-up? HOW do you find it?Tom
          • #6
            Where did you "tee" in your vacuum gauge? That engine should not pull that kind of vacuum unless there is a problem in the fuel delivery system.What's under there, you ask?? Well a black poerhead (hot), a cover that's possibly a dark color, regardless, when it's on it holds the heat in. Fuel in the carb bowls will vaporize due to the higher temps (higher octane fuel makes it worse) and vaporized fuel won't go thru the system. The engine won't run well until the vapors are cleared out and liquid fuel get to the carbs...-John
            • #7
              Well, I tied in the vacuum gauge in the line going to the vacuum switch that controls the warning light. 4" is fine. A momentary reading 6" on a throttle burst is to be expected. The warning horn is not set to go off till about 7" or so.Thanks for the lesson on the contents under the cowl. If fuel vaporizes in the float bowl of one carburetor then logically speaking fuel will vaporize in all the carburetors in all the engines of the same color on the same lake on the same day. That doesn't happen. If it did, everyone in Florida and other southern states would be constantly having this problem, especially in the summer.I more suspect something in the electrical arena that is affected my the high temperatures. I don't know if the spark advance on these engines is mechanical or electronic. SOMETHING is being affected, and it's NOT on ALL 1996 Johnson 175's.Tom
              • #8
                4" of vacuum is too high, that is the max. recommended by Johnson. Going even higher on acceleration, 6", is even worse.A good fuel system will have about .5" to draw the fuel thru 8' of 3/8" hose, 1.5" for a good anti-siphon valve, and an addtional .5" for a spin-on fuel filter. That makes 2.5" which is attainable but most boats are just below 3". The more vacuum in your lines, the quicker the fuel "boils" or vaporizes.There was a good article about a year ago in Bass and Walleye Boats about this and how to test it.
                • #9
                  Vacuum is exacrtly the same for both tanks. Would vacuum be high if the tank switching valve was not completely switched. Factory didn't do so hot a job there.What would be the down side of simply removing the anti-siphon valves from the tanks tops?thanksTom
                  • #10
                    Seahorse is absolutely correct. 4" vacuum is too much. Make up a tee with two 3/8" id fittings for the fuel supply lines and use whatever size fitting your vac gauge requires for the 3rd fitting. Connect it to the fuel filter inlet (on the engine) and re-run your test. Move the gauge back to the next connection closer to the fuel tank and re-run the test. Repeat this procedure if necessary until you get back to the tank. At the point your vac reading falls to normal levels, the restriction is located between the last 2 test points. If you have high vacuum at the tanks, suspect an issue with the fuel pick up.Every Johnson outboard in FL isn't the issue, yours is - it's the one with excessive vacuum. Feceral law requires some form of anti-siphon protection. Only a qualified tech should look at your boat and make the call whether or not to remove it. I'm not going to accept that liability over the net. You are correct regarding the switching valve(s), they are a potential source for the problem, as is every hose fitting from the tank to the engine. They should all be 3/8" for that engine. It's very common for the boat builders to put in cheaper ones that are usually 5/16". Don't neglect to consider a fuel supply hose either - they are made with a heavy double-walled construction. Although a hose may look perfect on the outside, the inner wall can colapse on itself and cause a fuel restriction. I've seen this a couple of times...-John
                    • #11
                      The test procedure makes perfect sense. Will try it tomorrow.Prolly just replace the gas line as a matter of course. It's cheap and an easy job.ThanksTom
