daphniesman04
- Jun 18, 2005
- 25
hello, i just bougth a pontoon boat with a 1987 johnson 110 vro outboard. J110TLCUR this is the model number. when i bought it it ran perfect, took it home . i noticed the pee hole werent peeing. so i want to replace the water pump impeller etc... problem is, i cant remove the lower unit. my outboard has the pin type connector for the shift shaft. and YES, i already released this pin. i have removed all 7 bolts. before i disconnected the pin, i placed the gear in forward. i have pushed the shaft toward the powerhead. it may have dropped 1/8 th of an inch , if that. i can wiggle it left to right but i cant get it to fall. i have beat it and pulled on it to no avail. i called a local boat repair and he said all he can think of would be to cut the shaft then remove the cut ends. then replace the shaft . basically he said im looking at 1200 .00 plus. he said the gears are rusted in place.... i just dont believe this. the motor runs like a champ. it shifts fine. prop spins perfectly. if this was rusted i would think this would be frozen in place am i correct ? what can i do to get it free ? notice, the previous owner really wrecked on this casing see the crack starting, i am scared to beat or even pry on it in this area because of this crack.......can anyone please help!!!!!!
