I NEED A GOOD USED P/N 392518.THIS IS THE STEERING ARM ATTACHED TO THE TOP OF THE VERTICIAL STEERING SHAFT.MINE IS EAT AWAY;IS THIS COMMON?EVIDENTLY THE ARM AND THE SHAFT ARE ONE PIECE.
It all one piece. Found mine on ebay used from a freshwater motor for 50 bucks. I think the part is 600 + new. Ouch! PITA to change out but if you take your time its not bad
