• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
6hp Evinrude Fisherman starter rope replacement
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 6hp Evinrude Fisherman starter rope replacement
    Please help, My Father-in-law has a late 50's early 60's 6hp Evinrude Fisherman motor that needs the starter rope replaced. If someone could give me some detailed instructions on how to do this it would be greatly appreciated.Thanks,Brett
    Re: 6hp Evinrude Fisherman starter rope replacement
    Hi BrettIf you could post the model # of that motor someone is sure to help.
    • #3
      O.K., I'm new to Outboard motor repair. The serial number on the motor is 6902M-E10160. Perhaps the motor is a 1969 model? Any help is appreciated.Thanks,Brett
      • #4
        Hi BrettRemove spark plug leads.Fully extend starter rope,then allow it to retract until knot on spool faces the port side (less than one revolution). Lock starter in this position by lifting starter pinion gear to engage flywheel. Hold it in place by wedging pliers handle under it. Pull old rope off. Cut a new rope to a length of 66 3\4" and fuse the ends for a 1\2". Tie a knot in one end. thread rope through hole in spool and through eyelet in motor cover. Secure handle to the other end. Remove pliers and slowly let rope retract. If you need to rewind the main spring. Use a heavy screw driver or a brace with a screw driver bit in it. Place driver in slot on the top of the spool and wind counterclockwise 18 turns. rope anchor hole in spool should face port side of motor. Lock in place with plier handle. Piece of cake. If you have any trouble let me know and I'll try to send you a picture. Oh yes, that motor is a 1969 model. Good luck have fun.
        • #5
          Thanks alcan! I replaced the rope yesterday following your instructions and it worked perfectly. One thing though the rope was about 6" too long, so I just trimmed it off.Thanks for the help,Brett
