I am new to boating! Problem: When I first try to start my 1988 Invader boat with a 90hp Evinrude it won't start. I press the bulb to prime and it is tight but won't start. I put a little starter fluid and it starts then stays running sometimes! I pulled the connection off the quick disconnect and pressed the bulb and to my amazement no fuel came out...like the line is plugged then I tried to disconnect the end into the boat and all of a sudden it freed up and gas came out. What do you think. Again once running the boat runs great. Just won't start first thing and the process starts all over. Thanks and need help!!
