Re: Need standard bore size for 1988 60 H.p. JOHNSON
I would think from standard bore size the machinist can determine the amount he needs to remove from scored cylinder or cylinders and use his final resurfacing as to what oversize piston will be used.20 over,30 over and so on.If other cylinders are within tolerance with stock pistons he can simply detremine from them as to bore and oversize.if all cylinders are scored or worn out of spec is when standard baseline would be of use.If he is generic machinist he will need your assistance in obtaining oversize piston as baseline for his work.
