Re: OMC Piston - vs - Wiseco Piston... and why?
Mr. Dhadley, Claytone, Walker and Hooty, I think that what caused the piston problem was the carbon build-up. However, I wonder if the carbon build-up was the reason (Which there was a lot of carbon in that whole) for the piston to break apart at the tip and chip off scouring the cylinder. Now I did notice that there was a slight color distortion. But I cannot be sure of this since all the tips of the cylinders are coated with carbon. Also, when I pulled the plug out of that port, ( the bad port) there was smoke coming out of it (like on a cold day when you can see your breath) but not out of the other ports when I pulled the plug out of them.<br /> Now you had said "Lug", would that mean to run the motor under stress ie., Towing a boat, running 1/4 trottle while viewing the ladies, lugging your woman around the lake or lugging all those waverunners that ran over cause they messed up the fishing and ruined the peace and quite?<br /> Do note, that some of the things mention above are not true. But on a more serious side, what would lugging fall under in your terms?<br /> I am leaning more towards Wiseco by the minute. Now the part about 5,800 rpms, is that to mean that the high end must reach that rpm?<br /><br /> Jimmy
