The boat was completely submerged in salt water. I have cleaned everything up as in the clymers manual. Replaced the key switch due to salt water corrosion as well as some other electricall connections. I was told I need to get this motor started to get the water out, time is of the essence. How do I start the motor without using the key switch, Are there a pair of wires I can jump? Please help.
