Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
How to HOT WIRE 1978 70 HP Evinrude
  • How to HOT WIRE 1978 70 HP Evinrude
    The boat was completely submerged in salt water. I have cleaned everything up as in the clymers manual. Replaced the key switch due to salt water corrosion as well as some other electricall connections. I was told I need to get this motor started to get the water out, time is of the essence. How do I start the motor without using the key switch, Are there a pair of wires I can jump? Please help.
    Re: How to HOT WIRE 1978 70 HP Evinrude
    Unplug the big red plug on the main wire harness and then jump the starter straight from the battery and it should have fire. You will have to reconnect the red plug to cut theengine off, either that or choke it down till it dies.
    • #3
      It seems when I have the spark plugs in, there is too much compression to turn over. With the plugs out the starter turns the flywheel fine. Just with the plugs in it is like one turn and jams up. Any ideas? Is it hosed?
      • #4
        Dusle, Did you get the water out of the crank case? Need to lay the motor down to do this! Then take the plugs out and crank it.The water can only get out thru the ported holes in the piston!steve
