Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Instructions For Changing Power Trim/Tilt Oil
  • Instructions For Changing Power Trim/Tilt Oil
    Can someone give me the instructions or a web site on how to change the power trim/tilt oil in a 1996 Johnson 90 outboard. Also what kind of oil to use?TIA
    Re: Instructions For Changing Power Trim/Tilt Oil
    I'm not sure if I'm the best person to give advice here but I'll tell you what I know. The only reason you should need to change the PT&T oil is if you have water in it. If the oil isn't milky all you should need to do is add hydrolic oil. On older engines I have used regular automotive transmittion fluid. I am not advocating this, I am only giving you some input. Personally I would go to your nearest marine outlet and purchase PT&T oil for Johnson & Evenrude outboards. Hope this helps.
