Re: How do I remove the lower unit from 1975 evinrude 135 hp
Man, I have an original owners manual and an original repair/parts manual. I'm sure I could scan and email you the instructions in PDF. I'm having problems myself and am likley going to have to remove the lower unit. Its the last ditch effort. Since were runnnin the same great motor that we are soo close on getting it running perfectly, I feel your pain.
See my post. Its long, but I would like to hear your thoughts on what I should do.
http://forums.iboats.com/showthread.php?t=554409&p=3891141#post3891141
Here is a post I just poset tonight..
Ok, I'm nearing the sell it and give up point.. but I'm too OCD for that probably. I'm so close to the boat being perfect! Recap of the problem. Compression is awesome, seems to shift very well, new gear case lube. The old lube was definately old...black as night, but no metal on the magnet (just some shiny dust when I whipe it off on a towel.. metal dust smaller than the head of pin. New Solaris Rubex propellor and greased it up good(so not a spun hub).I adjusted the timing as the orginal manual said. I've been on the lake with it twice since my last tread. Thank god I have a trolling motor.. lol.
Both times before I hit the lake, I put the muffs on, i push the button and it starts and idles great. I shift into forrward gear.. the prop spins in the correct direction, and as i increase the spead the prop also increases spead. It spins FAST. Same in reverse.
I get it in the lake. I start it up..starts up nice, sounds great.. Put it in drive and all I get is splashing and bubling watter from the prop spinning. If I bring it up to where the prop is half way visible, its spinning like any other boat i've seen spin..throwing a lot of water up in the air but not in a completely rear spray.. kind of up and a little out. The boat doesnt move. If I do this in reverse, it splashes (significantly to where it worried me I'd take on water. I have a video of this, I need to get it from a buddy and I'll post it.
One thing I noticed. If I put it in reverse, full throttle down... I hear some clicking. So i did that no more.
So how is it even possible that if the thing is shifting, spinning very fast, that the dang boat wont move!? lol. Its killing me guys. The boat is light..17 foot and I can pick the front of the trailor myself and move it.
I look at this diagram.. http://www.marineengine.com/parts/jo...ction=Gearcase
same as in original owner manual and part manual. And I dont see a shear pin.. is their any other kind of safety piece possibly? And would my prop spin like it does it is in safe mode?
I am thinking maybe the timing needs to be adjusted because over time the motors timing specs have just changed? Does anyone know how to easily do that without just checking each grove and starting it up and trying each one? And I guess i just need to take the lowe unit off..find something on youtube on how to do it and check all the gears and see if they all look ok?
Any Ideas? Guys If you can solve this over forum, you are a boating mechanic god! And I will worship you! haha. But really, pleeeeease help. Its going to drive me nuts. I want to catch some dang fish!! The trolling motor isnt going to cut it. lol "
So send me a message and lets figure out what you need. Its actaully a very precise manual. I think it will help you a lot. Also, if you end up giving up and seals are the only problem, I will buy your motor!. lol. But I'd rather you get it running. Such a beast of an motor.
