Evinrude 50 1990, Vacum crankshaft pressur
Big Brother
I have som problems wiht the vacumpump/fuellpump on me engin. It looks like the vacum from the crankshaft is too low. Can anybody tell me what the pressur should be??
eric_rudd
Re: Evinrude 50 1990, Vacum crankshaft pressur
Dont know anything about the pressure in the vacuum-pump, but there must be a users-manual, or service-manual with desciptions of these things. Is'nt there someone that has a drawing and/or descrition of the fuel-pump, so that we can disasseble and rebuilt the ****ed thing ?
clanton
Fuel pressure at idle should be 3 psi. Crankcase pressure 5/7 psi. If VRO, did you check the pulse hose?
Big Brother
It is a VRO engin yes. Can you tell me what a "pulse hose" is? Is it the hose that is coming from the oiltank and ends in the fuelpump?
clanton
The pulse hose is the hose from engine crankcase to fuel pump.
