Hi, I have a 8hp Johnson extra long shaft that I want to convert to a short shaft. I have found the proper driveshaft and shift rod to do this. I will cut the water pipe to the correct size. My question is: when I remove the block below the water pump and pull the shift rod out will I beable to slide the new shift rod back into the shift cam with out having to go into the gear case? Thanks....Robert
