I took a negative wire and touched it to the positive wire on the trim gauage.<br />The lights went out and the switch stopped working while wiring up the lights on the trim gauage.<br /><br />Did it blow a fuse...where are the fuses located on the motor and ignition switch?<br />How can I fix my problem?
