• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
evinrude lightwin choke problem
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • evinrude lightwin choke problem
    I have a 1964 evinrude lightwin 3 HP. The engine runs with the choke fully deployed, however; when it is pushed in any degree the engine will stall....Is this a carberator problem? any help on steps to diagnose and fix would be greatly appreciated. Also having trouble locating a manual for this engine, any thoughts
    Re: evinrude lightwin choke problem
    Try this link: http://www.maxrules.com/fixtuneitup2.html Scroll down a bit.You can also search this forum.Good luck!
    • #3
      bean--I have a 1967 Lightwin that has been in the family since its orginal purchase as a new motor. It runs fabulously, and always starts. One option for your problem may be OLD gas. I hadn't run my motor for awhile, and found I needed to choke it to run. I dumped the old gas and ran fresh gas which fixed the problem. Also, you can go to www.kencook.com for manuals. I got a Johnson Service Manual, and an original owner's manual for a 1956 Johnson 7.5 from them. I found an orginal parts manual on ebay. The Maxrules site is great by the way. Good Luck.
