• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
what do i have ? old Johnson
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • what do i have ? old Johnson
    Help, need info : Johnson model# jh21e serial# E2695342thanks forany helpScott
    Re: what do i have ? old Johnson
    1966 3 hp
    • #3
      Thanks dont have a manual yet . pot this motor in water and ater many years in someones shed , took me two pulls and she wants to run so bad. will start right up but die after a few second ( is there a fuel pump ? or is this a drip type system? all lines look good . any ideas are appreciated .Scott
      • #4
        Thanks dont have a manual yet . put this motor in water and after many years in someones shed , took me two pulls and she wants to run so bad. will start right up but die after a few second ( is there a fuel pump ? or is this a drip type system? also whats the correct mixture? all lines look good . any ideas are appreciated .Scott
