• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
1978 Johnson Javelin 85HP cold starts
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1978 Johnson Javelin 85HP cold starts
    My 1978 Johnson 85hp (Model# 85ETLR78C Serial # J8004158) does not want to run properly on cold starts. I need to constantly use the choke to keep the motor running. It starts and revs to about 1500 RPM and then will slowly die.Choking when RPM hits 1000 keeps the engine running and RPM goes back up to about 1500 - 1800. I may need to choke the engine on a hot day 10 -12 times before it will run without stalling. No other problems at all.Carbs repaired with new floats and needles.
    Re: 1978 Johnson Javelin 85HP cold starts
    Your fuel pump might be weak and not working properly at low rpm. rebuild it. It is a simple operation.
    • #3
      Mine's a Johnson Javelin as well and I had the same or similar problems. I found it went away after I replaced the spark plugs and changed to Penzoil oil. I know it sounds like an advert but it worked for me without any other problems.Ross
      • #4
        From your post I gather once the motor is warm it's OK. If so I think we can rule out the fuel pump. It should misbehave cold or warm. What fuel are you running? Make sure it's FRESH 87 octane. Spark plugs should be Champion (Q)L77JC4 or similar Champion plug. If you are running a higher octane or fuel older than 30 days with another brand of plug it may have something to do with the slow warm up process. Also make sure you are running thermostats. Good luck!
