• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
1980 115 Johnson vs 1982 115 Evinrude?
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1980 115 Johnson vs 1982 115 Evinrude?
    Are the 1980 115 Johnson V4 and the 1982 115 Evinrude V4 motors the same except for deacls? I am replacing my 115 Johnson with a 115 Evinrude. I am I correct in assuming these two motors are almost identical and are interchangeable? If not please let me know before I make a big mistake.
    Re: 1980 115 Johnson vs 1982 115 Evinrude?
    Only the names are changed to protect the innocent....go ahead everything will swap across. There might be slight differances in parts (improved slightly) in the newer one.Bob
    This is a great link to boat specifications http://boatspecs.iboats.com/
    Please, shop iboats first!!
