• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Water Pump 76 Johnson 85 HP
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Water Pump 76 Johnson 85 HP
    Does anyone know where the water pump is located in a 1976 Johnson Javelin 85 HP?? And how hard is it to change??
    Re: Water Pump 76 Johnson 85 HP
    a
    • #3
      Not really a big job. The water pump is located on the inside of the lower unit above the gearcase. Get a manual or hit the library. Another excellent source of info is the Search function on this Web site.
      • #4
        Ok, glad to see that it is a farely cheap part, and somewhat easy to do!! I did search the site, and seen that the main thing to worry about is lining the water tubes up correctly when you put it back together. Thanks!!
