• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
How can a 1972 6hp Johnson be checked for RPM
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • How can a 1972 6hp Johnson be checked for RPM
    I recently acquired a 1972 6HP 2CYL Johnson outboard. I had to put on a new prop as the other one had a piece missing. I replaced the 2 blade with a 3 blade and the boat seemed to go slower. Had the prop shop "tweak" the prop for less pitch and it ran faster but he said to get the maximum efficiency from the prop, you need to know what the RPMs are with the throttle wide open under a load. It was suggested that I need to hook up a tachometer. How can I do this and is it possible? Would appreciate any information. Bob H.
    Re: How can a 1972 6hp Johnson be checked for RPM
    Piece of pizza, Bob.Get a marine Tach that can be set for a 2 cyl. engine. Follow instructions.Good luck.
    sigpic
    • #3
      Thanks JB for the reply on my 1972 Johnson 6hp rpm Question. The problem i am finding is that most marine suppliers can get dash mounted guages for big $$$ , when i only need some kind of a hand held one for small $$$ as i only have 2 motors and will only use it to check motor rpm a few times. Any Thoughts.....Thanks......Bob H
      • #4
        They are called tiny tach and are a simple install and also fairly cheap. http://www.tinytach.com/tinytach.html
        • #5
          Thanks YEPBLAZE for the TIP , I will check into it looks good.
