• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Johnson Trim & Tilt problem
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Johnson Trim & Tilt problem
    I have a 91' V-6 (loop) 150hp Johnson. Runs greatand I love it, but, when I trailer it the trimstarts working by itself within an hour of doing so. I hit the trim button on the motor or theshift and it quits. Logic tells me this is not good. Why is it doing this and how can it be corrected. Need to know before it tears itself up.Many thanks
    Re: Johnson Trim & Tilt problem
    sometimes relays shed a little amount of their contact material through arcing. This material can float around in the relay housing. If activating either TnT switch stops the motor, I'd suspect the relays. If you are maticulous, you can disassemble the relays and view the debris. Its tricky to take them apart without braking the plastic housing. Putting in new ones might be the answer. If the trim motor always creeps in the same direction, try swapping relays with each other, and see if the up or down direction changes as well.......
    Alias "schematic"
    • #3
      Schematic, I've had relay problems before, severalyears back. I got a couple extra to switch out.I think you solved my problem, I did'nt knowrelays could do that. Thanks for the help.
