• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
1991 Johnson 115 HP Engine Knock
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1991 Johnson 115 HP Engine Knock
    After running across the lake, I slowed to cross a large wake. When I slowed, I noticed a knocking noise coming from the engine. I turned the engine off and removed the cover to inspect. Everything looked fine. I cranked the engine and it still knocked. I figured it was a goner, so I ran at 3000 RPM back to the marina. As I idled through the marina the noise faded. Finally at the dock, the knock had disappeared. In neutral, i ran it at 3000 rpm for about 30 seconds but no knocking. Back at home, I hooked up the garden hose and ran engine tuner through the engine thinking i might have carbon build up. After sitting for several hours, I ran it several minutes at different RPM's and still no knocking. It clearly was not a lower unit noise. Any ideas what it could be?
    Re: 1991 Johnson 115 HP Engine Knock
    Sometimes, two strokes that aren't getting enough oil will knock under load. Also extreme heat can cause one to knock. Hopefully it is something simple.
    • #3
      Could this be an indication my VRO is not operating correctly?
      • #4
        I must appolgise I do not know a lot about boats, but if a VRO is an oil injection system I would suspect it could cause the problem. I have worked on a lot of two strokes race bikes. Most two strokes that are not getting enough oil will knock first, then if loaded hard enough or lack enough oil will seize. The seize may only last until the engine cools, but you can be sure it is damaging. I am not sure this is what is happening. It is only one possibility
        • #5
          IF this is a crossflow engine, I would check for loose upper crankshaft bearing housing bolts, and drain gear oil and check for chunks of metal.
          Help somebody every day, if you can.
          • #6
            The gear oil was clean and in good shape. No metal shavings were found in the oil or on the screw magnet.
