Was running my outboard yesterday and boat stahled somewhat on top end (wasn't maxing out rpm's) so I stopped the motor to check maybe if it was trimmed wrong. Well after that, I couldn't get it back started. I check electrical and its getting spark to both cylinders, but now when I try to start it and it wont start...gas starts dripping / pooling a little out of the lower unit (exhanust and holes)...is the gast / oil mix...not lower unit oil.
Wondering what this may be indication of? What I need to check. I have pulled and went through carbs before if this seems it may be that...just wondering why the gas was leaking out the bottom.
