• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
!988 Johnson, electric primer(choke)
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • !988 Johnson, electric primer(choke)
    I bought this motor used with no book. Where is the manual lever on the primer supposed to be set at. Also do you hold the key in for several seconds or do you pump it in several times? How is it supposed to be operated? I'm having starting problems and I don't know if this is the problem. Is it supposed to squirt gas with the switch if the handle is turned all the way clock-wise? This is on a 50 horse with VRO. Thanks
    Re: !988 Johnson, electric primer(choke)
    BJ.... The red handle on that primer solenoid should be facing straight back in line with the solenoid. That is the default automatic position.Think of it as a choke. Holding the key in when cranking, or when the engine is running causes the solenoid to open its internal valve, which forces fuel into the intake leaf plate area.Turning the red lever to the opposite position puts the solenoid valve in a manual open position. This is used only should the electrical system fail and you need to prime the engine. With the lever in this position, pumping the fuel primer bulb would force fuel into the leaf plate area.
    Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
    • #3
      If the primer is squirting gas when you push the switch, the cover may be cracked. You can get a replacement cover and gasket. Replace that and you will find the motor starts easier and runs better. Plus there will not be gas flowing around under the cowl.
      Age and treachery will always overcome youth and enthusiasm
      • #4
        Kinda strange, but I called 2 marine dealerships asking this before I got home to read these replies. One told me to leave it open to adjust the spray for cold starts, and the other told me it didn't matter where you left it because it was electric anyway! What you guys have told me makes sense. I think this is what has been causing all my flooding problems and my CARBON PROBLEM!!! I don't think I'll call those 2 places again for any advice! Thanks, guys.....
