• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
lower unit leak
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • lower unit leak
    hi. i have a 1972 johnson 25hp. please excuse lack of terminology. i have done lots of repairs to various motors for the last few years, just dont know terminology. i just got the motor this fall. after changing the gear oil, a few hours later i noticed a few drops dripping down on to the skag from the propeller shaft. i went to my local parts dealer and he gave me the o-ring and the spaghetti seal. i cleaned everything off really well, the o-ring rubber went on well, but when i went to put the long rubber on, it was really skinny compared to the old one, and was really loose in the groove, and way too long. i assumed it was just a standard cut-to-size thing, but it still bugged me how skinny it was. anyways, i put it in the river this afternoon, ran the motor for about 30mins, pulled it out, and got straight milk. by the way,the guy tried to sell me the big metal piece at the end of the shaft that seals the shaft, but as it was $140 i figured i'd try the other 2 seals first. i waited 5 hours after replacing, and no oil on the skag. whats up? thanks!
    Re: lower unit leak
    sounds like you got the wrong seal. Even if you get the right seal, I usually use sealant between the housings. Did you put in a new lip seal for the prop shaft? Did you replace the drain and fill screw gaskets?
    Alias "schematic"
    • #3
      Re: lower unit leak
      Here is how to determine just what is leakin where:Get a bicycle pump with a gauge on it, or an air hose with a gauge that you can hook to the VENT or FILL screw holes.Submerge the foot in a tank or garbage can (this can even be done still mounted). Charge the lower unit with about 10PSI,and look for bubbles. It's bulletproof, finds the leak every time.When testing, The unit should hold 10PSI without leaking down too.
      "Did you hear about the guy whose whole left side was cut off? He's all
      right now."
      • #4
        Re: lower unit leak
        hi schematic thanks for your quick reply. i don't know what the lip seal is. i did not replace the drain, fill plug seals (didnt know i could) but will tomorrow. not sure if they were leaking, but there WAS a leek from the back near the prop, cuz i saw the oil path. my dealer said i should replace the metal piece that the 0-ring fits on to, but as it was $140 i did not. is this the lip seal? tim
        • #5
          Re: lower unit leak
          hi 12footer. that is an excellent idea. i will find the stuff tomorrow and give it a try. tim
          • #6
            Re: lower unit leak
            Here are the leaking points on your gear box. As 12' says, find the leak before proceding. I'd advise you to use sealant along both O-rings. Especially where the spagetti seal terminates....
            Alias "schematic"
            • #7
              Re: lower unit leak
              hi schematic. what kind of sealant? i have high-temp gasket maker. will this do? do you put it only along the outside edge or all over the gaskets?
              • #8
                Re: lower unit leak
                okay i have completely replaced and sealed everything on the bottom end including fill/drain washers and shifter pin o-ring. STILL LEAKS!! i have the o-ring and seal for the top end, and have dropped the leg. thats as far as i have gotten. can anyone PLEASE give me a detailed guide as to how i change these 2 parts? do i need anything else before i procede? the long weekend is only 9 days away and i must fish!! thanks loganmallory
                • #9
                  Re: lower unit leak
                  Hi LogonNow that you have your lower unit removed from the motor, you will need to disasemble it. Again. Odds are its the shift shaft o-ring thats leaking. You will need a long punch to remove and replace the o-ring and bushing. You can order one from your dealer or make one up. As for the drive shaft seal, you can carefully pry it out. I like to tap them out from the bottom with a long rod with short 90 bent on the end. You realy should have a manual, short-cuts rarely pay off.
                  • #10
                    Re: lower unit leak
                    loganmallory You can procede to replace all the seals, or you can pressurize the unit and check for leaks as 12' says. Lip seals can be pryed out or driven out with a long punch. Be sure not to scar the housings. The seals should be pressed in dead straight or distortion will cause leaks. Use a sealant on the seal and housing when pressing in the seal to its bore. Red loctite or crankcase sealant work well. You can also use crankcase sealant to seal the housings together along side and on top the o-rings.
                    Alias "schematic"
