does any one know how much gear oil should be added to the bottom end ?
T troutman Recruit Joined Apr 28, 2002 Messages 2 Apr 30, 2002 #1 does any one know how much gear oil should be added to the bottom end ?
Joe Reeves Supreme Mariner Joined Feb 24, 2002 Messages 13,262 Apr 30, 2002 #2 Re: super 55 Evinrude commercial Troutman..... You'll see a large slotted screw at the skeg. You'll see a identical screw near the top of the lower unit. Fill from that bottom screw hole until it flows out the top screw hole.
