• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
WOT Sputter
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • WOT Sputter
    I have a 1985 50hp Johnson it runs great until I run it at full open, then I can hear it sputter a little. If I back off just a little it runs normal. Any ideas as to what could be the cause of this?
    Re: WOT Sputter
    air to fuel ratio, try adjusting the jet.
    • #3
      Re: WOT Sputter
      To eliminate a fuel pressure issue, try squeezing the primer ball when its sputtering. If it cures it, its a fuel supply problem (restriction in tank, hose, filter, fuel pump issue etc.)....The main jets could also be partially plugged. Try engaging the primer when the sputtering occurs. If that cures it briefly, its a fuel starvation issue.If the above doesn't affect it,I would go through the synch and maximum timing adjustments as well....
      Alias "schematic"
      • #4
        Re: WOT Sputter
        Thanks, Snuffyzz and Schematic!!! I will try the squeezing the primer ball when it sputters.I have located the original owners manual that came with the motor, its a little molded and tattered but I can still read it. I notice it refers to a section called "engine over speed". It says the ignition system is equipped with a limiter circut to help prevent engine damage due to overspeeding. If the engine overspeeds the limiter circuit will activate causing the engine to run roughly or misfire. This sure seems to be what it is doing. I think maybe the limiter needs adjusting. Does anyone know if this can be done and where it is located or how to do this? If anyone needs a scanned copy of a 1985 40/50hp Johnson VRO I would be more than happy to e-mail it to you. -I know these things are hard to come by. xray_74134@yahoo.com
        • #5
          Re: WOT Sputter
          Hi Makkodo you have a tach on board? If so, what RPM does it go up to before misfire?
          Alias "schematic"
          • #6
            Re: WOT Sputter
            Hi MakkoI just mailed youWhich boat is this motor on, and which propeller do you have. Maybe that is the problem.Dane
            • #7
              Re: WOT Sputter
              start with the basics first before ripping into it you could just have a ht lead breaking down or a bad plug,although rev limiters will give the symptoms you describe and no they aren't settable but on some engines you can cut the wire for racing purposes but i wouldn't recommend doing it.
              • #8
                Re: WOT Sputter
                No tach on board at this time..I plan to put one on in the next few days. I took it out for a test run yesterday (and some fishing) I could give it full throttle until it got up to speed then it started sputtering. I think it must be the limiter. I do need a tach so I can check the RPM at WOT/full speed. I will scan the manual tonight and sent it out. Thanks allfor your help
                • #9
                  Re: WOT Sputter
                  Don't get carried away troubleshooting until you check the RPM....
                  Alias "schematic"
