• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
1994 evinrude 50 hp oil injected
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1994 evinrude 50 hp oil injected
    I have a 94 Evinrude 50 hp oil injected motor on my 20ft pontoon boat that misses at low to medium speeds and it has a rough idle.I have had it tuned & the carbs cleaned it helped a little but the problem still exists. I called Evinrude they said it might be a thermostat running to cool. does anyone out there have any suggestions, please e-mail me. thanks
    Re: 1994 evinrude 50 hp oil injected
    Check the VRO pump pulse hose, on some of these engines the starter rubs a hole in the hose. If the carb was realy gummed up, you may have to push a small copper wire throughthe idle tube and passages ways to clear the gunk out. Check coil, and plug wires.Check roller in linkage that advances the timing, nearly everyone I look is missing the clear plastic outer cover, the roller should fit the slot with just enough clearence to roll.
    Help somebody every day, if you can.
    • #3
      You said the motor runs rough at low speed. Is this also what you describe as a miss or does it just idle poor and rough? You could be dealing with two different problems. If I was looking at it, the first thing I would do is make sure the compression is still good in both cylinders.If compression is good I would make sure that all the syncronization and linkage adjustments are properly set. You will need a good reputable service shop to make sure this is done properly. Can't tell you how many times I've solved running problems with nothing more than a good linkage set up and carb adjustment.A cold running motor will definitly cause a poor idle condition. Usually the thermostat can be cleaned of debris and not have to be replaced. As far as a miss at medium speeds, hard to say without seeing it. I have seen a few 40 and 50s with a chaffed wire behind the bracket the ignition module bolts to. Under certain throttle settings the wire shorts to groung creating a miss.
