• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
  • **** The forums will be undergoing maintenance tonight approximately 9:30pm-midnight MDT. Thank you for your patience during this time. ****
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
5.5hp Johnson
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 5.5hp Johnson
    Hi,I've been watching this board for some time and there's a wealth of information here.I'm in the process of repairing/rebuilding a 1978 21' Dolphin Products boat with a 175 hp Evinrude (which I bought, boat motor & trailer, for $800.00, so that tells you the shape it was in). I've replaced rings, bearings, water pump, etc in the motor and it seems to run ok on the muffs. The boat has been cleaned up, fuel system added, repaired in several areas, and the seats and controls redone. I'm working on the trailer now and when it's ready we'll go have our maiden voyage.This question concerns a 5.5 hp Johnson that I bought (for $100.00, another "project") to use as a "kicker". It's a Model CD 195, Serial 22968677. I want to buy a manual for it and need to know the year. Does anybody have that information? I'm planning on fishing for "Specks" in the Mississippi sound.Thanks,Bill......
    Re: 5.5hp Johnson
    Model CD 195, Serial 22968677No such Model, might be typo......Model CD 19Year 1962HP 5.5The Model ID number is essential for us to ID your engine, see below to locate:For Johnson and Evinrude outboards, check the following locations: -the stern mounting bracket -the freeze plug -the flywheel -the side of the cylinder assembly For OMC Stern Drives: -the nameplate attached to the rocker cover -the front and/or the rear of block, behind or in front of port cylinder head -rear of block, port side, below manifold -the starboard side, above the starter motor ------------------"Keep It Between The Bouys" & "Good Luck"!!!fone_man
    • #3
      Re: 5.5hp Johnson
      Thanks, fone_man.That's the model number on the bill of sale and I read it from the plate on the stern bracket. It's not a typo, but it may be a "read-o" on my part. I'll look at it again when I get home. 1962 sounds about right however, judging by the color of paint and the style of the hood. Are parts still avaiable from the dealers, or on-line? Bill......
      • #4
        Re: 5.5hp Johnson
        They should be... new or used, this a great BB for locating hard to find parts plus I am always searching for new sources.Walt & JB profess to be experts on old OB's & they do a great job along with 12footer & the rest of the crew... "if I didn't mention your names, please do not be offended"...Just remember to post all info in as much detail as possible so we can get to "the rest of the story" In regards to old manuals.... check out this site for OMC products... using "print on demand" technology for old owners & service manuals... I have enjoyed the history section of this company... the timeline & technology that owner used to grow his business was the best at the time & he had a vision that is still growing the companies business to this day!!!Check it out & I hope it helps.... http://www.kencook.com/kccwww/marine...arinepubs.html ------------------"Keep It Between The Bouys" & "Good Luck"!!!fone_man
        • #5
          Re: 5.5hp Johnson
          Thanks, I'll try that.I'm looking forward to getting this rig in the water.Bill......
          • #6
            Re: 5.5hp Johnson
            Mornin' allfone_man, you're right. After carefully looking at the tag on the stern bracket it turns out that the model number is CD 19 S.Another question. I'm building a bracket to mount this motor on the back of the boat to use as a kicker, and I'm wondering where the shaft length (15", 20" etc.)is measured from. This little motor measures about 20" from the top of the inside of the stern clamp to the propshaft. The 15" measurement is about 2" above the anticavitation plate. I'm gathering diminsions so I can build the bracket to allow the motor to tilt up enough to clear the water line when underway. I have read that the anticavitation plate should be level with the bottom of the boat to about 2" below the bottom of the boat when underway. Is this correct? Bill........
            • #7
              Re: 5.5hp Johnson
              The Ken Cook Co. has your manual.Its a bit pricey @ $35 but is the best manual I've found(I have a CD-17)Also E-Bay has lots of original manuals, parts catalogs and parts.Local marine dealers still carry ignition parts for it also.Plenty of on-line parts dealers also and most have search engines and will mail you the results.
              • #8
                Re: 5.5hp Johnson
                Thanks Rick C,I've checked out Ken Cook and Monday I'll give them a call and order the manual.I've gotten the motor running this weekend and it seems to run ok but the fuel pump does not work. I'll try to find a diaphram locally next week.Also I had to take the carb apart and clean it and I found the low speed adjustment set at 1/4 turn off the seat. Does anybody know what the correct initial settings are for the low and high speed adjustments?I've gapped the plus at .030 and I guess thats's ok, but if not someone please let me know.Bill......
                • #9
                  Re: 5.5hp Johnson
                  The saga continues,I've disassembled the fuel pump and lo and behold the problem does not appear to be the diaphram. It looks like there are two ball bearings that are used as one way valves to contol the direction of fuel flow through the fuel pump. I say it looks like it because if they are supposed to be installed they are missing. The cavitys are there, the seating surfaces look ok, and the springs that should hold them against the seats are installed. There are no ball bearings however. I can also blow both ways through he pump so it's definately bad. Does anybody have any thoughts on this?The fellow I bought the motor from said it was running before he stored it several years ago. I don't think so.Bill...
                  • #10
                    Re: 5.5hp Johnson
                    Well I visited my local dealer and while he had no parts to repair my fuel pump, (the parts manual listed no parts for it) he did have a complete pump that would work. I purchased it and hopefully will be able to try it tonight.I still would like to know the initial settings for the low and high speed jets, and the spark plug gap.Bill........
                    • #11
                      Re: 5.5hp Johnson
                      Ahoy, Byordy. Set the hi-speed needle 1/2 turn out from the seat, lo-speed needle 1-1/8 turn.Plugs are J4J, .030, points at .020.Red sky at night. . . JB
                      sigpic
                      • #12
                        Re: 5.5hp Johnson
                        Thanks, J.B.Hi J.B.I put the fuel pump on this afternoon, set the mixture screws, turned on the water, pulled it twice, and it ran. After some fiddleing with the mixtures it purrs like a kitten, (a 39 year old kitten). A little cosmetic cleanup and some other minor things and it will ready to mount on the boat.Now to build a kicker bracket to mount it on...Thanks, Bill........
                        • #13
                          Re: 5.5hp Johnson
                          i have the some motor model # CD-20R seriel # 2390668 will start but wont idle would appreiciate any info you could supply this is the perfect size motor for my 12 v bottom boat i would love to get it in the lake this season thanks for any info jnallyn@netzero.com (jeff)
