• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Need Prop Help!
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Need Prop Help!
    I have a 35hp Johnson(not sure what year model, probably early '80's.) The prop has 10x13 stamped on it. When I look for a new prop do I have to get one with the same stamp, or can I use another size? If so what is recommended? Also what do the numbers stand for? Thanks in advance for any help.-Brandon
    Re: Need Prop Help!
    The numbers are the pitch you can use 10x13 10x15 10x17 the difference will be inhole shots and trolling speed.
    • #3
      Re: Need Prop Help!
      Hello Brandon.The question cannot be answered without knowing the size of your boat and the load you put on your engine as far as weight in the boat is concerned.Go to www.miwheel.com and their website will ask you a series of questions.In the end you will know what size is good for your situation.stay afloat!!!
      Make sure the plug is in
      • #4
        Re: Need Prop Help!
        It's me again.The first of the two numbers you mentioned ,is the diameter of your prop,the second is the "pitch" .Imagine your prop cutting through jello in one rotation it will move 13 inches forward through the jello.It has to do with the angle of your blades.The lighter and smaller your boat,the bigger the pitch you want.The bigger and heavier the less pitch.rolmops.
        • #5
          Re: Need Prop Help!
          I tried the website, but I don't have all the answers for the questions so therefore I can't get an answer. Let me try and give you some ideas of what I have and maybe I can get a recommendation.1982 35hp Johnson14ft 48"wide aluminum boatGross weight w/passengers is approx. 900-100016" transom-Brandonmodified-V Hull
          • #6
            Re: Need Prop Help!
            Just a thought. If you have a tach and you are revving too high, (suggested rpm range should be stamped on the motor somewhere) every inch of pitch increase would lower your rpm by 200. Diameter would remain the same +/- depending on manufacturer.I ran a 10x13 on a 35 hp, 14' fiberglass bass boat. You are about 400 lbs lighter load. Mike
            • #7
              Re: Need Prop Help!
              I can't find any info about the RPM's on the motor and I don't have a tach either. Mike,If you ran the same size motor w/400# more weight does that mean I should go up a little on pitch? And if so how much? What would be the main difference if I changed from a 10x13 to a 10x15 or 10x17? Would the boat go faster? Would that put more of a load on my motor? Sorry for all the questions, but I need to learn somehow.-Brandon
              • #8
                Re: Need Prop Help!
                Hi Brandon,Usually the higher the pitch the faster you go; however it's like Mc Gluclen said,you should use a tach. your engine is designed to run at a specific RPM at wide open throttle. If it's running too fast it can damage the engine , and if it's running too slow because of the prop it will cause the engine to lug,or strain therefor damaging the engine. I would borrow or buy a good tach to determine this. I don't know what the recommended RPM's of your engine are,but if yiu can wait until tomorrow I'll look it up and let you know.
                • #9
                  Re: Need Prop Help!
                  Possibly a 15"......but as almost retired again says get a tach. No where near as expensive as a new motor. I will guess that manufacturer rec. is from 4500-5500 rpm but not sure. Look on the port side of the motor mounting bracket. It should be stamped there.
                  • #10
                    Re: Need Prop Help!
                    Thanks for all the replys. I'll look again tomorrow to see if I can find the recommended RPM's. The guy at the boat shop today told me he thought it would be right around 5200. If that's the case which prop should I go with? How hard is it to install a tach? I'm going to look into one tomorrow as well. Thanks again for all the helpful info.-Brandon
                    • #11
                      Re: Need Prop Help!
                      Well I found the Tach info. It is 5200-5800.-Brandon
                      • #12
                        Re: Need Prop Help!
                        Hello again Brandon,Well as promised I have the specs, but someone else has already answered you. Anyway the service manual says it's rated to run between 5200 & 5800 the max HP is developed at 5500 RPMs. If you have an induction tach. connect the pick up around any spark plug, wire or coil primary wire start your engine and read the RPMs. The manual recommends a good prop to start with on your boat is a 13X15.Hope this helps
                        • #13
                          Re: Need Prop Help!
                          Okay, now that you found that out, buy or borrow a handheld tach if you don't want to install one. Post your full throttle rpm, under load (in the water underway) just dont let it go over the max stated. To be honest your boat sounds a little overpowered. Dang thing should fly once it is set up. Mike
                          • #14
                            Re: Need Prop Help!
                            I thought that since I had a 10 x 13 now that I had to stay with the 10 x ?. Almost Retired said that it recommended a 13x15, would this stilll fit my motor? I'm trying to locate a tach to borrow for now, then I can go from there.-Brandon
                            • #15
                              Re: Need Prop Help!
                              HEY bRANDON Sorry about the typo,I don't think a 13X15 would fit. Ment to say a 10X15Sorry I can only type with 2 fingers
