Hi I have a 1975 70 hp johnson 3 cylinder.I was going fine then motor stoped like I turned off key now there is no spark.I read other posts with same problem the replys all said to replace power pack or stator. I replaced power pack no help.How can a stator stop spark if it only to charge battery.I have a manual and have performed all tests all are ok Iwill order new stator.But how about the timerbase under stator.I am new to outboardsand would appreaceate any help
