• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
fuel/air control/adjustment
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • fuel/air control/adjustment
    What is the proper way to adjust the Lean/Rich adjustment on an older style 9.9 Johnson? The knob works, and you can tell a difference when you turn it, but you can pull the knob off, and reinstall at a different setting. Since this engine is new to me, I'm wondering if, after years of use, that it is way out of adjustment? Is there a way to tell? or should just adjust it until the engine runs best at idle? at high rpm?Also, if anyone knows where I can find the rubber boot that covers the stop button, I'm in the market for one.
    Re: fuel/air control/adjustment
    try ckg out this place: http://www.maxrules.com/johnsonboatmotor.html
    • #3
      Ebbtide, its good to hear about your experiences in Valdosta. I love Rays Mill Pond too. Actually, I don't live very far away from there. The motor idles higher and runs smoother when I turn it up to rich, but it smokes a lot more of course, and I was wondering if the richness was overcompensating for a dirty carb. or other possibilities of wear/failure. Give me something to think about guys!
      • #4
        yo waco>be sure to have fresh fuel>be sure the fuel mixture ratio is correct>have engine warmed up>adjust idle mixture screw for highest smoothest idle>reinstall knob to center of its travel *If the carb has only the idle adjustment, it will have minimal affect on high speed. In other words, the high speed mixture will be determined by an internal orfice size and float level.pardon me while I cough my brains out.....got the flugood luck!
        Alias "schematic"
        • #5
          so........I should turn the adjuster in (getting richer), until I find the smoothest idle, then reinstall at mid-range? Thats easy enough. Thanks Scem.
          • #6
            Waco,You got it. The numbers or notches you see are just reference points for your future use. You can take the knob off and install it upside down if you prefer.Just adjust the idle to where it sounds good by ear. Make sure the engine is warm though.
