• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
1969 Johnson 55 hp
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1969 Johnson 55 hp
    I have this outboard. Its 3 cyl., It ran fine 10 months ago. Now trying to start andno fire. Appears to have no spark, checkedall plugs. Not very problable they all failed at once. Next thought is points. Where are they located and how hard is it to change. Any help is truly appreciated
    Re: 1969 Johnson 55 hp
    I am not familiar with that model, but I have a 79 Johnson V6. No points, it has a 2 powerpacks and six coils(one for each plug). I would assume your engine has 1 powerpack and 3 coils. Check those first.
    • #3
      there are points under the fly wheel but they are unlikely to be the problem.On the left rear side of the motor (looking from front)you'll see a box with wires coming out of it (CDI,POWER PACK) what the tech. name is i am not sure but this is probably the problem. You can do a low tech test on it without removing it.One of the wires that comes out of it goes up under the flywheel it is on the same side of the motor behind the throttle linkage.It has a connector which you can disconnect and with the key on touch the wire coming from the box to the bolt that the the wire coming from under the flywheel is attathced to(good ground)to if you can hear a buzzing (electrical type sound) the box is probably good. If the box appears to be good an ohm meter connected between the wire you tested and a good ground will test to see if the points are opening . with the meter attatched and the key off rotate the flywhhel slowly and the reading should turn off and on. I am by no means an expert but i have owned a couple of these motors so i have some experiance.good luck and let us know how you make out
