1996 Johnson 225 Ocean Runner
Pro23
18 volts output. What is wrong with my motor ? Rectifier/Regulator ? HELP !
Dhadley
Re: 1996 Johnson 225 Ocean Runner
Yes. Fix it now before something worse happens.<br /><br />Good luck!
Pro23
As best I can tell it is the Regulator. Can something else have caused the regulator to go out ?
Dhadley
When you replace the water cooled regulator, go ahead and install the fitting to vent the block to avoid a repeat failure.<br /><br />Good luck!
