• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Johnson GT 150 20' LOWER UNIT
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Johnson GT 150 20' LOWER UNIT
    Hello all, I just got my boat back from mechanic for lower unit reseal job and he told me that when he finally got the unit apart (had to use heat) that he did not get the warm fuzzies at what he saw. There were pieces of gear metal which he managed to to get out and he said I should start looking for a backup lower unit soon. I change lower oil after each outing hoping to make unit last til new one can be found. If anyone can find me a good CHEAP lower unit I sure would appreciate it.Thanksemail mkasper@swri.edu
    Re: Johnson GT 150 20' LOWER UNIT
    Forgot, motor is 1990 GT 150 W/ 20'SHAFT
    • #3
      Do good and cheap mean the same thing? Sorry! I couldn't help it. Just can't help but wonder why you don't just replace the gear set now while the case is still good. If you want a GOOD replacement at a FAIR price call Jack at Superior Marine at 800-338-9281. If you choose to have the unit rebuilt be very careful whose gears you use. There are some really bad pieces out there right now.Good luck!
