• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
motor bogs down at full throttle
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • motor bogs down at full throttle
    We have a 98 25hp Evinrude that has an annoying habit of intermittently bogging down or losing power when we run at full throttle. One of the problems is that it is completely unpredictable as to when it is going to happen. When it happens we stop the motor take it out of the water for a minute or so, start it back up and it works fine. (At least until the next time.) Does anybody have any idea what this could be?
    Re: motor bogs down at full throttle
    Howdy, gone_fishin'. Sounds like fuel starvation to me. Check that the air vent on your fuel tank is open and not blocked, that there are no air leaks in your tank-to-motor hose, and that your fuel pump is in good shape.Another possibility is overheat Check out your cooling. Have a good stream of lukewarm to hot water (no steam)from your tell-tale? probably okay.A blocked or closed air vent on the tank will look unpredictable because how long it takes to starve the engine depends on how full it is. An unvented full tank will develop a vacuum pretty quickly, while a near-empty tank may take half an hour to do the same.Hope that helps. JB
    sigpic
    • #3
      I have a 1996 25HP Evinrude that I bought new in 1998. I have the exact same problem as you described. I will be cruising along at full throttle, then, without warning, and very abruptly, the motor slows down almost to a stop. After about a second it goes back to full throttle. It is very intermittent; sometimes it won't happen for weeks, other times it happens 3 times in an hour. Here's what I have tried: I cleaned and rebuilt the carburetor (twice), replaced the fuel tank, fuel hose, primer bulb, checked all electrical connections. I have tried bringing it to a so-called "Authorized Repair" shop. The mechanic told me I had carbon in the cylinders. He replaced the head gasket, charged me $105, and did NOTHING to fix the problem. I just took the boat out Tuesday for the first time this spring, and the problem is still there. I bought a new fuel pump yesterday. This week I will install that and try the motor again. This has been very frustrating! It's nice to know that someone else has experienced this problem. Keep me posted, and I will do the same.
      • #4
        Thanks richk!Yeah, it sounds like we are having the exact same problem. You are a lot farther along in the leg work than I am though. At least I know what NOT to try. Let me know how the fule pump goes.
        • #5
          gone_fishing and richk possibly that modeldevelopes a vapour lock in the carb and by tilting the motor it unlocks. Additives havebeen developed to prevent it. To mechanicallyadjust something I would guess changing floatheight.------------------
          • #6
            sony2001, My motor clears itself without tilting it. I have checked the float level while in the process of rebuilding the carburetor. So, I don't think that would be a problem. Thanks for the suggestion, though,richk
            • #7
              I have a 1984 Yamaha 50hp, 3 cyl, oil injected, outboard motor, low hours, and is in fairly new condition. At full throttle, it bogs down. I've changed the gas lines, tank, and fittings. The water pump works fine and the water is luke warm. The repair manual doesn't help either.
              • #8
                Hey, wizard. Most likely fuel starvation, but could be ignition timimg or spark strength as well as more obscure causes. Stop buying and replacing stuff until you zero in on the real cause. You could end up broke and still have a misbehaving motor.Quickie fuel pump test: Pull the fuel line off of one carb. Place it in a can or plastic bottle and turn the engine over for a few seconds. If you get strong pulses of fuel in the bottle (about 1oz. per second)your pump is probably okay. If they are weak, overhaul your fuel pump. Do this in the open, away from any source of fire or spark.Carb/ignition narrowing test: You say the engine bogs. Do all three quit or could only one be cutting out? If it is only one, find which one by pulling the plug wire and listening for changes. When you have isolated which one is cutting out, swap the ignition parts for that cylinder with one of the good ones, one part at a time. If the trouble moves to the new cylinder, replace the last part you moved. If you can't move the trouble this way, try moving the carb. If the trouble moves, overhaul that carb.If it is all cylinders failing, check that your ignition timing is being advanced smoothly with the throttle. You can do this by inspecting the linkage while advancing the throttle without starting the engine.If the above fail to isolate the problem, tell us what you did and what you found out. Then we'll try again.Good luck.JB
                sigpic
                • #9
                  Hello allI can see a lot of possible errors, I have one more.My guues is the plugs. They might get overheated, maybe an cooler or warmer type than the standard.I no mechanic, so maybe I'm wayout.Mikael
                  • #10
                    An update on my 1996 Evinrude. I put a new fuel pump on a few days ago, and took the boat out to a local lake yesterday. I ran the motor wide open for about 20 minutes straight, and it never flinched once. I'm not going to break open the champagne yet, because I've been down this road before; where it looks like it's fixed, but two weeks later it acts up again. All I can say now is "So far, so good".
                    • #11
                      I have a 92 ,50 hp yamaha, with Jet drive, the boat sat for 4 years, Then I got a chance to work on it. Took off the bowls and cleaned out the jelly, dumped the fuel and started fresh, new plugs, new oil, Nothing, got the carbs rebuilt, new fuel pump, new oil pump, Now it will run, choppy, then overheat, ? I put on a new fuel line with new bulb, no good, The boat ran fine 4 years ago, then went kapoot, all the time I have been blaming the gas, but I think it's time to blame something else. Any Ideas??? thanks.
                      • #12
                        Ned, what compression readings does your Yammy have?
                        • #13
                          Thanks for the note, never checked the comp, just going by the fact that it ran great before it was parked. The only info I get out of the book that I haven't checked is the adj jet settings on the sides of the carbs, top one is one turn, second one is 1 1/2 turns, etc. or something like that. I will check the comp, what am I looking for???
                          • #14
                            Well, my problem turned out to be nothing more than a gummed up carb. We took it in to the shop after putting in a new fuel pump didn't work. All they did was spray some Mercury Power Stroke in the carb, etc... And Wholla! Anyway, feeling dumb now...
                            • #15
                              No, GF..Don't feel dumb. You did good. When the carb is gooed-up,this just means the original problem made it all the wayt thru your fuel system.Now, with clean fuel tanks, fuel lines,filters, fuel pumps and carb, you should be back to normal.But keep it running by running it often,and not lettting old fuel go bad in the clean tanks. Try to run them close to dry before switching-over to the full tank, and carry a one gallon can with enough 2 cycle oil (6oz) to mix in the event you do not make it to the dock.In other words, don't run the risk of running out of fuel, but also,don't allow gas to sour in the tanks, by figuring fuel consumption,and keeping a resrve you can dispose of at the end of the day, by using it in your tow vehicle.I've never had to use my reserve in the engine,but I've also never returned with more than 3 gallons of fuel in my boat's tanks.
                              "Did you hear about the guy whose whole left side was cut off? He's all
                              right now."
